I have a F4-3200C14D-32GTZR kit together with an ASUS B550-E Gaming motherboard and a Ryzen 5900X CPU and everytime
I have disconnected the PSU for a few hours or more and start up the computer I get "0d" debug code and DRAM light is on and nothing else happens. If I press
the reset button the computer starts without problem and is stable. Can run memtest86 for hours and also other test programs.
I have the CPU at stock (tried with only PBO enabled and same thing) and loaded the D.O.C.P profile.
The problem does not occur if I use the JEDEC speed and timings (2133 MHz).
I've tried:
The modules are in the correct slots on the motherboard according A2/B2 to the manual.
Anyone have a clue what I can try?
I've tried:
- Setting the timings manually and also
- Used DRAM Calculator for Ryzen and used those timings
- Tried different ProcODTs
- A few different voltage bumps to CPU SOC, VDDG and VDDP.
- Up the DRAM voltage all the way up to 1.4v
- Tried using 2T CommandRate instead of 1T.
- Tried BIOS versions 1804 and 2006.
