Hello Gskill!
Inside of the Lighting Control software, is if I try to change any RGB by single DIMM vs sync all 4 DIMM, slot 2 and 3 are always swapped.
Nothing I do will fix this issue. Basically if I was to modify any rgb settings by single DIMM, it is ALWAYS “1/3/2/4”.
I have Trident Royal Z rgb, 64gb 3200mhz cl14.
At this point I have had this ram in multiple systems that range from an i7 6700k, i5 10600k, and finally its residing in a Ryzen 9 5900x/x570.
All of these systems have seen multiple format installs over their lifetime.
I have also played musical chairs with the stick vs DIMM slots, MULTIPLE times.
help
help
