Recently built a pc that has the following specifications :
PSU : Corsair SF 750
CPU : Ryzen 9 5950x / Ryzen 5 3600x
GPU : RTX 3090 Ventus
Board : ASUS x570 I Gaming
Problem is my F4-3600C18D-GTZN wont post on rated XMP profile on both CPUs
Test done (All test done after clearing CMOS, CPU and GPU stock)
2133mhz JDEC - Pass
3600mhz 18 22 22 22 42 - Default XMP - 1.35v Failed
3600mhz 18 22 22 22 42 - Default XMP - 1.4v Failed
3600mhz 18 22 22 22 42 - Default XMP - 1.45v Failed
3200mhz 18 22 22 22 42 - Manual OC - 1.35v Failed
3200mhz 18 22 22 22 42 - Default XMP - 1.4 Failed
3200mhz 18 22 22 22 42 - Default XMP - 1.45 Failed
3200mhz 18 20 20 20 38 - Manual OC - 1.35v Pass
3200mhz 18 18 18 18 38 - Manual OC - 1.35v Fail
3200mhz 18 18 18 18 42 - Manual OC - 1.35v Fails
any other tighter timing than 18 20 20 20 38 - 1.35v Fails
all test done with my backup 3600x and new 5950x same results
this 3200mhz 18 20 20 20 38 is horrendous timings. what else should I try or should I just RMA ?
2133mhz JDEC - Pass
