Hola. I haveing issues with my first build when using these ram sticks Ripjaw V 32GB 2 x 16GB DDR4-3600 PC4-28800. This is my first pc build the set up is Ryzen 7 3700x, Gigabyte X570 Aorus AM4 mITX AMD Motherboard, sapphire pulse rx 580 8gb, EVGA SuperNOVA 650 GM, 80 Plus Gold 650W. I originally used Trident 3000 32gb the machine was fine. After I install the 3600 Ripjaw I have restarts and crashes, my video glitches sounds makes static etc. As soon as I switch to the Trident 3000mhz its fine. So before returning the 3600mhz I wanted to see if there could be another solution. Can anyone help? Thanks.
Issues with Ripjaw V 32GB 2 x 16GB DDR4-3600 PC4-28800
