MSI X470 GAMING M7 AC with G.SKILL TridentZ RGB F4-3200C16Q-32GTZR
  • MSI X470 GAMING M7 AC with G.SKILL TridentZ RGB F4-3200C16Q-32GTZR
    Hi all,
    I have purchased MSI X470 GAMING M7 AC and unfortunately, I forgot to double check the RAM. So, i end up buying G.SKILL TridentZ RGB Series 32GB (4 x 8GB) DDR4 3200 F4-3200C16Q-32GTZR. Also, my CPU is AMD RYZEN 7 2700X.
    Unfortunately, I didn't know the G.SKILL has different naming for AMD ram. In this case, instead of F4-3200C16Q-32GTZR it should be F4-3200C16Q-32GTZRX.
    Do you think I will have any compatibility issues with this ram and motherboard? Will, i able to use on 3200? Or should i be worried?
    Looking forward to hearing from you all.
