Hi there
Just wanted to ask what the latest status is regarding compatibility of the TridentZ RGB DDR4 modules with AM4 platforms.
My specific build will be a Taichi X370 with R5 1600.
The kit I'm looking at is F4-3200C14D-16GTZR - according to all the research I've done, this should be compatible. However both the QVL for the motherboard, as well as the Gskill QVL seem to be outdated.
Other lists also mention the -16GTZ version but not specifically the -16GTZR. AFAIK they have the same Samsung b-die chips, but I would appreciate some confirmation/guidance.
Am I likely to run into problems, and if so, how should I anticipate to manage them?
Thanks for your help/input!
