need help with ram timeing M5A78L-M LX PLUS G.skill ram F3-12800CL9D-8GBRL
  • need help with ram timeing M5A78L-M LX PLUS G.skill ram F3-12800CL9D-8GBRL
    need helping with ram timing M5A78L-M LX PLUS AMD Athlon II X3 450 Rana 3.2GHz Socket AM3 95W Triple-Core Desktop Processor ADX450WFGMBOX
    ram F3-12800CL9D-8GBRL http://www.newegg.com/Product/Produc...ab=true&Page=5
    Initially I'd try 1333, 9-9-9-24, 2N (or 2T if the T designator is used), with DRAM at 1.5. Your 450 may not be able to run 1600 sticks, generally the 965 C3 is considered the first AMD CPU to be able to consistently run 1600 sticks, can see the AMD freq guide here:
    http://support.amd.com/us/kbarticles...encyguide.aspx
      For that CPU, the best setting will be DDR3-1333 8-8-8-24 1.50V
