Hi everyone !
I buy this memory, it's a 4Go barrett:
http://www.gskill.com/products.php?index=316
I would want to know if she was compatible with this mainboard, M4A79XTD EVO:
http://www.asus.com/Motherboards/AMD..._EVO/#overview
The 790X chipset which seem to be compatible with the memory, finally the M4A79T Deluxe is supported... But this memory is supported:
http://www.gskill.com/products.php?index=225
She get the same timing, CAS and voltage, but it's only 2GB. They are rather similar to to my memory.
Do you that will work fine ?
