Not booting up
  • Not booting up
    So here's my situation. I just got my RAM that i ordered(F3-10600CL8D-4GBHK), i installed it and now
    my pc won't even boot up. The display screen stays black and no beeps from
    POST. When i removed the RAM that i had purchased and reinstalled my old
    RAM it booted up just fine. Is this a compatibility issue, or is it simply faulty
    RAM?
    My PC specs:
    Model of the motherboard: M4A77TD
    Model of the memory: AX3U1600GB1G9-CG
    Model of the CPU: ADX435WFGIBOX
    Are you using only the G.Skil kit? Test one at a time to see if one is bad.
      I tried to run it with one of the sticks in every slot and i got nothing.
        Do you have other memory you can try?
        Did the motherboard work before? Or is it new?
          Yeah, i still have my adata ram and that one works fine.
          Boots right up the way it's supposed to. I purchased my mother
          board on 4/20/2010, but it still works fine as long as i have my adata
          ram in there. It will not boot when i try using gskill ram that i bought.
            Send the G.Skill memory in for RMA to see if a new kit works better. Or try the F3-10666CL8D-4GBHK model.
