Hello everybody
I recently installed the G.Skill F3-12800CL7Q-8GBECO on an Intel DP67BG Board. Unfortunately it does not work with the provided "XMP-1600" profile. When I choose this profile the board fails to POST when checking the memory (I see the POST code on the board's LED flashing up before restarting). I reset the BIOS to use the AUTO profile, which means the RAM is now running on 1333MHz and CL9 and manually decreased voltage to 1.35V.
Is there a trick to get this to work using the XMP-1600 profile or what can I try?
Additionally, what are the exact settings for this RAM in the BIOS?
The profile gives me the following settings in the BIOS:
tCL 7
tRCD 8
tRP 7
tRASmin 24
tRFC 88
tRRD 5
tWR 12
tWTR 6
tRTP 6
tRC 39
tFAW 50
Command Rate Auto (maybe it detects 1T? didn't try so far)
Voltage 1.35V
Regards, Lucent
tCL 7
tRCD 8
tRP 7
tRASmin 24
tRFC 88
tRRD 5
tWR 12
tWTR 6
tRTP 6
tRC 39
tFAW 50
Voltage 1.35V
Regards, Lucent
