You should be using memtest86+ v4.10
You are using an old version that does not support your system.
With Win 7, type "mem" after clicking on Start, and that will prompt for the Windows Memory Diagnostics test.
For that memory at DDR3-1600, use the DDR3-1333 setting, but raise CPU bus speed to 240. This will overclock the memory to DDR3-1600. Then make sure there is enough voltage, 1.50V or 1.60V.
For fail proof settings, you can attempt DDR3-1333 8-8-8-24 1.50V. Keep us posted on the results.
