I was just wondering if the Ripjaws f3-10666CL8D-4GBRM RAM is compatible with Gigabyte GA-880GMA-UD2H motherboard?
I got this combo a few weeks back (i didn't bother checking the compatibility - silly me)
Mind you, it still seems to be working (i know its not on the qualified vendors list tho).
I was getting the occasional blue screen of death in windows (3-4 times in a month) but then i checked the timing and the auto timing was set incorrectly, so i set it to 8-8-8-24-2N and 1.5v and is yet to get a blue screen (been ok for 2 days so far but im still not sure if this will stop the problem)
But when i do a memory test i get nothing but errors ...
Is this ram compatible with this motherboard? Or could the errors indicate faulty ram?
regards,
martin
regards,
martin
