Mobo - ASUS P7P55D-E
RAM - G-Skill F3-12800CL7Q-8GBECO
CPU - Intel i7 860
BIOS - AM 0610 (latest)
PSU - Corsair 650w
Windows 7 pro. X64
My computer wouldn't resume from standby (S3) with all 4 sticks installed.
By noticing ASUS board POST state LED checking key components,system freezes on resuming cycle, with
DRAM LED staying lighted, telling me the problem should be memory related.
So, swapping sticks and using different slots I discovered the problem is coming from one stick. The system
doesn't resume when this stick is installed in any slot.
Otherwise my system is running smoothly and fast with 2 or 4 modules
(Windows experience index of 7.6 with 2 sticks and 7.5 with 4 sticks).Memtest reveals no fault.
Is that behaviour unusual? I'm wondering if I should RMA my whole kit or only 2 sticks. How important is the
use of a 4 modules kit vs 2 X 2 modules?
For information, the two settings shown below provide me with normal stable operation, apart from standby.
issue.
AI Overclock Tuner - XMP (Correct SDP values shown)
CPU Ratio Setting - Auto
BCLK Frequency - 133
DRAM Frequency - DDR3-1600MHz
QPI Frequency - Auto
DRAM Timing Control (submenu)
CAS Latency - 7
RAS to CAS Delay - 8
RAS PRE Time - 7
RAS ACT Time - 24
tRFC - Auto (88)
DRAM Voltage - 1.35v
CPU PLL Voltage - Auto (1.8v)
DRAM Timing mode - 2N
_____________________________ ______________
AI Overclock Tuner - Manual
CPU ratio setting - Auto
Intel SpeedStep Tech - Enabled
Intel TurboMode Tech - Enabled
PCIE Frequency - 100
OC Tuner - Good Performance
(1st information 7-8-7-24-5-88-12-8-24)
CAS Latency - 7
RAS PRE Time - 7
RAS ACT Time - 24
Ref Cycle Time - 88
DRAM Timing Mode - 2N
CPU Voltage Mode - Offset
All others AUTO
Any comments?
CPU - Intel i7 860
PSU - Corsair 650w
Windows 7 pro. X64
issue.
CAS Latency - 7
RAS PRE Time - 7
RAS ACT Time - 24
tRFC - Auto (88)
CAS Latency - 7
RAS PRE Time - 7
RAS ACT Time - 24
Ref Cycle Time - 88
All others AUTO
Any comments?
