I have an ASRock P55 Pro/USB3 & F3-8500CL7S-4GBRL GSkill Ripjaws and this DDR3 will not work in this motherboard. Works fine with the 2 1GB Samsung DDR3's in it.
Reset CMOS, set everything to default, will boot and Windows 7 either will not boot or errors. Put Samsung back in, works fine.
Tried one GSkill at a time, crashes.
All memory settings set to auto.
Using Memtest86+ on a USB, runs for about a minute then locks up, both sticks of GSkill.
Not trying to overclock either, just trying to get it to work.
Settings suggestions? 2 bad sticks of RAM??
Checked and it is supposed to be compatible with this motherboard.
