I just joined the forum recently and am having issues installing the R9 290 with this setup. With a quad SLI GTX295 setup it is fine but with the new card I get 0xa0000001 BSOD errors, which might be the result of an "overclock". However, I never was able to get the RAM running at the right settings. I am also running a I7 2600K at stock settings (3.4 GHz).
I have tried XMP settings to raise the ram to 2133 MHz, and I believe it runs stable on the GTX295s, but with the new video card it is being really picky. I have ran the ram at 9-11-9-28 settings with 1.64V, which is still BSODing. I am not sure if there are some custom settings for this combination of RAM and motherboard that's rock-solid for stability, as I am not looking to overclock but just have a working system.
I have tried the card in my roommates computer and was up and running in 15 minutes with no setup in the BIOS. The card does work, but it appears it does not like my current settings
If there is a stable overclocking setup that also works, please let me know as I am open to trying anything but there are a lot of settings in the BIOS for custom RAM settings.
Additional technical info:
I am running the F7 bios and have reset the CMOS to fail-safe defaults and went from there. I tried about all MHz settings on the ram from 800 MHz to 2133 MHz.
