F3 2400C10Q16GZH on X79-UD3 rebooting
  • F3 2400C10Q16GZH on X79-UD3 rebooting
    Hi, I just got my Ripjaws Z F3 2400C10Q 16GZH today, but after installing them and adjusting bios settings , the system just keeps on rebooting over and over again (never comes to the windows 8 logo).
    Mobo: Gigabyte X79-UD3
    bios: latest F12l
    cpu: intel i7-3820
    power: 750W
    OS: Windows 8 64bit
    gpu: 2x ati radeon hd 6900 series (crossfire)
    XMP on profile 1
    mem voltage @ 1.65V
    What am I doing wrong or is there something not compatible with the memory.
    greetings
    thx
    Rozano
    Might want to try them at 2133, both the 3960X and 3970X can have trouble hitting 2400, some 3930Ks can (haven't seen many), but haven't seen any 3820s hit 2400
      thanks for replying, I will try this.
      though I find it strange that this important information isn't mentioned on the website or the pc-store or on the package itself.
        So after some tests I found out that 1 of the 4 sticks is giving the rebooting problem.
        When i put in that specific one, the pc won't start.
        when I run with the other 3, I can set the frequency up to 1866mhz.
        When I set them to 2133mhz the system stops and starts again in Bios mode.
        I also tried it with Vtt voltage @ 1.25v like it would do in XMP profile 1 mode, but then the systems tries to reboot over and over without getting in to bios and I have to do a "clr cmos".
          Might post up your BIOS settings, especially the DRAM timings (base and advanced/secondary) as well as your system voltages
            I took some pics from the bios screens. hope this helps.
              Let's start by taking the CPUVTT up to 1.17 and try
                No that didn't work.
                I raised the cpuvtt to 1.17v and win 8 was starting up normaly (mem@1866mhz). But when I then raised the memory multiplier to 2133mhz the pc fails again just after leaving bios.
                  Try 1.2 on CPUVTT, and raise your OC a notch or two
                    First, I would really like to thank you for helping me.
                    second, I went back to the computerstore and let them check out the mem kit.
                    They came to the conclusion that the memory kit was broken, I did not work.
                    So I got my money back (no other memory in store), so I could reorder a new set.
                    I just order the RipjawsZ F3-19200CL11Q-16GBZHD
                    I hope that this kit will work without any problems.
                    greets,
                    Rozano
                      Glad to hear it worked out, let us know how the new set goes when it comes in
                        today I received the RipjawsZ F3-19200CL11Q-16GBZHD memory set.
                        And this time it works.
                        only a little thing:
                        first I did a bios-reset to start fresh (previous memory ran at higher voltages)
                        Then I put in the new memory sticks but the system didn't boot.
                        When I put in only 1 stick, the system booted into bios.
                        Changed the settings (xmp profile 1 & voltages) and left bios , placed the other 3 sticks, and then system starts without a problem.
                        And as you said @2400 the system is not stable with the i7-3820, after a while pc freezes.
                        So I have it running @ 2133mhz now.
                          Sounds like a good setup for the 3820, some of them even have problems at 2133, so you have a good one
