I have an HP a1410a Desktop Computer
It has a Intel Pentium 4 running at 3.06 GHz, Runing Windows XP Home.
Motherboard ID is 63-0100-000001-00101111-090506-RS400$RC410-M
_BIOS DATE: 09/05/2006 VER: 08.00.12
Using the most recent BIOS available.
According to HP, the memory slot specs are:
2 x 240-pin DIMM sockets support unbuffered non-ECC 400/533 MHZ DDR2 memory modules
Maximum HP/Compaq approved memory is 2 GB
It currently has 1 Gb memory single card which is a
DDR2 PC2 4200 4-444-11-81
I purchased a Gskill DDR2667 PD2 5300 1024MB x 1 CL5-5-5-15 1.8V
to try to increase my overall memory to 2 GB.
My computer does not recognize the memory in the 2nd slot.
If I install either memory in slot 1, the computer recognizes
it and it runs fine.
If I install either memory in slot 2, with nothing in slot 1, the computer does not
operate.
Neither memory is recognized in the 2nd slot.
If I run ONLY the Gskill memory, the BIOS identifies it as PC2 4200 memory.
My main question is: Is the additional memory slot showing empty because of the 2 disparate types? (PC5300 & PC 4200)? - Or is my 2nd memory slot bad?
Do I just need to buy another Gskill DDR2 - PC2 5300 to have my
computer recognize 2 Gb?
Thanks, in advance, for any guidance.
operate.
