I'm thinking about acquiring some memory from eBay. They are DDR2-800 PC2-6400 1 GB modules. The labels on the heat spreaders list the product as being F2-6400CL4D-2GBHK with clock timings of 4-4-3-5 and operating at 2.0-2.1v. The clock timings seemed unusual so I thought I'd check them out on G.SKILL's web site but they aren't listed. If they're legitimate, I'd hate to pass them up. Can anyone supply a link to the data specs. if they're real? By the way, I have only 28 hrs. to make a decision.
Memory Specifications
http://www.newegg.com/Product/Produc...82E16820231114
They are legitimate, but that is considering they are still working to specification.
If you RMA, you will receive 4-4-4-12, because that kit is no longer available.
