I have a Gigabyte GA-X48-DS5 and have been trying to get the 1100 L2-8800CL5D-4GPI (x2= 8g) to work with 8gig ie: 4 x 2 gigs (the silver heatsink version)So far, its been impossible, I have gone to forums, tried others settings...It will not work...
Ever since I purchased this ram, about 2+ years ago, I could NEVER use it over 4 gig max. I feel cheated by it.
I have gotten 3 replacement MB from Gigabyte because of this problem, and the most recent one, is brand new. I also have a new replacement Intel Quad Core 9550 : LGA 775 processor; and a new replacement power supply Corsair 1050....
...STILL..., this annoying ram will not work with 4 sticks/8gigs, ... not only that, but now I can only use 1 stick ie: 2 gig in the new replacement MB. If I put more than one in there, the graphics just will not come on...., and/or it just reboots...
...in desperation, I decided I will not let this G.Skill ram cheat me of being able to use 8 gigs ram (with Windows 7 - 64 bit - Ultimate), and have ordered some Kingston Hyper-X ram x 8 gigs to replace the G.Skill pi.
I decided that before I pick this ram up, I will give the G.Skill pi x 8 gig ONE more go, by posting this on the G.Skill tech forum...., so that in case there is a quick-fix-response : THAT WORKS : I can cancel the order for the Hyper-X and use the G.Skill I have. Otherwise, I will just take the Kingston RAM and ditch the G.Skill as a bad purchase decision, at least for Gigabyte MB's, in fact, I am wary of getting them ever again for any board...
...but 'just in case' there is a solution to get my MB working with 8gigs without ANY glitches....I am posting this in the hope that there is a solution/setting and I have not just thrown my money away into the 'wind of glitchy or substandard electronic mistakes'....
I suspect that this G.Skill ram and/or my attempts to get it going, may have caused the MB; CPU and PSU faults to occur...I dont want to take that chance again, and risk using this ram..., unless there is a clear-working-fix for it....
So..., are you aware of this problem? and what is the fix/solution - if any ???...can you please let me know ASAP ...,thank you
