Need help getting F2-8500CL5D-2GBPK to 1066 in Asus M4A78-E
  • Need help getting F2-8500CL5D-2GBPK to 1066 in Asus M4A78-E
    Build a new system and need help with what to set in the BIOS to get my memory at 1066. It shows as 400mhz in cpu-z under memory frequency. I horribly when it comes to anything in the BIOS.
    Asus M4A78-E
    AMD Phenom 9600 Agena Quad Core
    1 pack G.Skill F2-8500CL5D-2GBPK
    Antec 1040 SX1040BII
    Corsair 750tx
    Asus M4A78-E
    Samsung SH-S223Q
    Western Digital Caviar SE16 320GB
    Winxp Pro
    You'll want to go into the BIOS and set the memory timings to 5-5-5-15, the voltage to 2.0 (maybe 2.05 or even up to 2.1, but I doubt it), and the RAM speed to 1066 (might show as 533), not familiar with the particular BIOS setup for this mobo.
    Also, check your version of CPU-Z, a couple of the latest versions have had bugs.
      Thank you for the reply.
      I'm not in front of the computer right now. But thought it had the those timings. Does the voltage effect speed? Or how does it?
      I was using cpu-z 1.50.
      Corsair 750tx
      Asus M4A78-E
      Samsung SH-S223Q
      Winxp Pro
        w/ 2.0 you should be able to run the RAM at stock settings, but that can vary from mobo to mobo (in part how they adapt the chipset to the board). Voltage can be used to stabilize the system and is used most often in OCing.
        Might also try CPU-Z 1.48.
        For your motherboard, you'll want the sticks in slots 1-2, the yellow ones (particularly if you plan to OC.
        Hope this helps, will be in and out of the forums this evening for awhile.
          Asus M4A78-E
          you'll need to set it at DDR2 1066 5-5-5-15 2T@2.0-2.1v manually in BIOS
          if you set it with auto setting, it's normal to run only DDR2 800
          and you may also need to increase northbridge voltage to run at DDR2 1066
          voltage would not improve performance but stability while overclocking
          thanks
          G.S
            Thank you for your answers.
            Went to try and small glitch. Got 4 numbers to change but 10 spots under DRAM timing.
            ILC 7clk dh only
            TRCD
            TRP
            TRTP
            TRAS
            TRC
            TWR
            TRRD
            TWIR
            TRFCO/TRC1
            Corsair 750tx
            Asus M4A78-E
            Samsung SH-S223Q
            Winxp Pro
              tCL - 5
              tRCD - 5
              tRP - 5
              tRAS - 15
              These are your primary timings.
                Thank you everyone for your help. Got everything set and is running at 535 (1070) so actually running a little fast.
                Corsair 750tx
                Asus M4A78-E
                Samsung SH-S223Q
                Winxp Pro
                  Enjoy,
                  Have a gud 1 !
                    we're glad you got it working fine
                    G.S
