I bought the F2-8500CL5D-4GBPK to go with an OC'ed Asus P5E-VM motherboard... but when I put the FSB at 320 and set DRAM to 1066MHz, the computer cannot post. It will only POST if RAM is set to ~1000MHz or lower
I was told in another forum that it's because the Trfc for the board is too tight (only choices are 20, 25, 30, 35, 42)... so the ram can't run stable at the stock settings.
Are there any solutions to this?
Thanks!
Thanks!
