compatibility
  • compatibility
    hello i have MSI K9A2 CF-F AM2+/AM2 AMD 790X ATX AMD Motherboard
    i was wondering if there are any compatibility issues with a G.SKILL 4GB 240-Pin DDR2 800 F2-6400CL6D-4GBMQ. at the moment im looking to upgrade to g.skill ram. and wanted to make sure they were compatible.
    thank you
    Smee342
    we tested it and found no compatible issue with this combination
    thanks
    G.S
      thank you G.S
      i just recieved my ram and its in great working order.
      thanks again
      Smee342
