F2-8500CL6D-4GBNQ w/ EVGA 780i SLI MOBO
  • F2-8500CL6D-4GBNQ w/ EVGA 780i SLI MOBO
    having problems getting this mem to run at 1066. i have tried a couple of things, only to get the long beep, followed by an error messae at startup. here is the rest of my system
    MOBO - EVGA 780i Triple SLI
    CPU - Intel E8500
    GPU - EVGA 9800GTX+ 512mb
    PSU - Corsair 750 watt
    Now then, I have 8 gigs of this ram, and would ove to get it to run 1066 instead of 800. I am not a pro, so as easy instructions as possible please.
    would you like to try to install 2 sticks first? since we do not guarantee for 4 sticks running together
    thanks
    G.S
      why wouldn't 4 sticks run together?? weird, but then again, would it be better to have 4 gigs at 1066 or 8 gigs at 800??? just wondering
        like 2 in dual channel, we have to test both sticks together to make sure the 2 could work fine in pair
        not every 2 sets could run together without problem, so we can't guarantee every four sticks could run together without problem
        for your choice, it depends on what kind of software you would like to run most
        and you have to use 64bit OS to get total memory available
        thanks
        G.S
