register
I RMA F2-8000PHU2-2GBZX and was wandering how you do this since I have read you don't carry the Micron D9 chips that are in this model? Can you repair them?
sorry, but we have to receive it first to see if we could repair it
if it can't be repaired, we'll replace a set of F2-8000CL5D-2GBPK, which is also DDR2 1000 5-5-5-15
thanks
If you haven't received it I hope it shows up shortly! But I got this ram for the overclocking and the F2-8000PHU2-2GBZX I sent in was known for top clocking according to this:
I have prepared a list of most of the DDR2 memory available nowadays.
The overclocking modules will be marked later with RED color, to have more clear visibility which modules all you Xtreme people should search
I received back F2-6400CL5D-4GBPQ???? I'm not sure if you guys meant to send me this set, but I have this identical ram in my computer typing this message. I bought some F2-8000PHU2-2GBZX to run with with my commando, but I don't want or need to try memory I already have, and I'm not sure what I should do???
you stated UR2082321 and it is request for F2-6400CL5D-4GBPQ, and for UR2083103, yes this is the request for F2-8000PHU2-2GBZX but we don't have any stock in US at this time. F2-6400PHU2-2GBHZ we have low stock but should able to change it.
