Motherboard: CPU Type QuadCore AMD Phenom II X4 920, 2800 MHz (14 x 200)
Motherboard Name MSI K9A2 Platinum (MS-7376) (2 PCI, 1 PCI-E x1, 4 PCI-E x16, 4 DDR2 DIMM, Audio, Dual Gigabit LAN, IEEE-1394)
Motherboard Chipset AMD 790FX, AMD K10 System Memory 4096 MB (DDR2-800 DDR2 SDRAM)
DIMM1: G Skill F2-8500CL5-2GBPK 2 GB DDR2-800 DDR2 SDRAM (5-5-5-15 @ 400 MHz) (4-4-4-10 @ 266 MHz)
DIMM2: G Skill F2-8500CL5-2GBPK 2 GB DDR2-800 DDR2 SDRAM (5-5-5-15 @ 400 MHz) (4-4-4-10 @ 266 MHz)
BIOS Type AMI (09/18/09) Communication Port Communications Port (COM1)
Video Adapter ATI Radeon HD 4800 Series (1024 MB)
AMD Phenom(tm) II X4 920 Processor
Operating System MS Win7
I am a new G Skill customer. I have had some problems running my memory at 1066 with the above settings/ hardware set-up. I have tried everything from your forums and i am still having some trouble. My timings are: CAS 5, TRCD 6, TRP 6, TRAS 24, TRC 30 as suggested but i do not know what to do about the TRFC because there are three different ones to fill out in the BIOS... When i do modify the TRFC settings I get a crash after the Windows logon screen. As far as I know i have been doing everything right but i cannot seem to get them to run at even 800 mhz. Can you please help me out?
My motherboard manual says nothing about configuring memory.
I have had trouble before with 4x1 GB of CorsAir Dominators which were obviously not going to work because of the nature of the AM2+ chips and thought i would give these a try. Unfortunately, nothing seems to work.
Is there anyone out there with a similar set-up that is running 800 or 1066 mHz stably that can maybe share their settings?
