First time poster, long time enthusiast.
Basically I currently own the following:
AMD Phenom 9950 Black Edition 125W
GIGABYTE MA790FX-UD5P
I have concerns on whether the board will be able to run a genuine 1066MHz DDR2 RAM and be stable. I've known there are some AMD issues as I've read through the MANY topics on the board whilst my account was being activated. What is going to compound my issue is that I intend to make use of the 4 DIMM slots and run a total of 8GB of DDR2 1066MHz RAM (most people are running only 2 sticks (4GB) and even they are having issues).
Now there are several references here which I will list at the bottom. Firstly, according to GIGABYTE, the RAM modules I wish to buy ARE supported. I find this interesting that people are having issues with the RAM. I've purchased GIGABYTE 790FX boards in the past (DQ6 actually) only to have DIMM slots 0 and 2 work (basically the yellow slots) and not the red slots (1 & 3). Many people in different stores (retailers) tried to fix the issue but they put it down to a bad batch of boards. It may not be entirely related but perhaps a slight coincidence?
Either way, I'm onto the UD5P board now and it does list support but was the support only with 1 stick, not 4 or does this not matter? What I'm trying to say, is if it supports 1 stick of F2-8500CL5D-4GBPK, will it support 4 at the advertised 1066MHz without causing stress to either the motherboard or processor?
If anyone is using a Gigabyte board with a 790FX chip, or just a 790FX chip from one of the big manufacturers can you please share your experiences (I've read a lot of the topics but now that some time has passed, are you still having issues, or success?) There are some others who share the same issue that I've had as well (listed below)
1// GIGABYTE MA790FX-UD5P Memory Support List.
2// Similar topic but with a Phenom II processor.
3// Another person running the same as above
Things to keep in mind, I will be keen to run 4 pieces not 2 and I want to run them at a genuine 1066, not 800. I will also be using Windows 7, 64 bit. Will my OS be a concern?
I appreciate any help you can give and have tried to do as MUCH research before posting the topic scouring newegg (I actually don't even live in America but sometimes find reviews of the products helpful) as well as other websites for info but could really use some answers, advice and more information.
