iMac F2-5300CL5S-4GBSQ
  • iMac F2-5300CL5S-4GBSQ
    I'm trying to figure out if my RAM (F2-5300CL5S-4GBSQ) is bad, incorrect, or not supported.
    I have a Late 2007 iMac (model 7,1) that according to Apple only officially supports 2x2GB but many people have a 6 GB configuration and places like OWC sell "supported" 4 GB DIMMs.
    When I install it and boot I get three beeps (signals bad RAM).
    Any help would be appreciated
    Does your computer have the latest BIOS?firmware?
      Yes the firmware is completely up-to-date.
        Will drop GSkill Tech a note, he knows what works with MACs better than I, don't want to suggest something that might not work
          The memory should be compatible as it does meet the specifications. Send it in for RMA to see if a new module works better.
          http://www.gskill.com/rma.php
