XMP Z5 Royal Not Working
  • XMP Z5 Royal Not Working
    Hi.
    Recently I decided to upgrade my 2x16GB GSkill to 2x32GB F5-6400J3239G32GX2-TR5S XMP 3.0 Ready in 5800Mhz frecuency, normaly I let that the XMP populates all the configuration but, in this case when I set any of the XMP (I, II, Tweak) simply not work the motherboard always shows Q-codes d0 or 31 and then restarts, verifying the temperature looks normal, so I don't know whats happening.
    It's worth to mention that with the previous Ram pack this errors didn't happen with the same 5800Mhz frecuency.
    This is my configuration:
    Intel Core i9 13900KF
    Motherboard Asus ROG Z790 Hero Latest version of the BIOS 2503
    2x32GB F5-6400J3239G32GX2-TR5S in Slots 2 and 4 as the Motherboard manual mention.
    Try one memory module at a time to see if both have the same results. If one performs differently, send them in for replacement. Each should be capable of XMP Profile on it's own in slot A2. Load optimized BIOS defaults, enable XMP Profile, save, exit, and see if that can work properly for each stick.
