Hum,
I was hoping for a bit more guidance on this one. You mention this kit as being top notch. I would be pleased with a speed of 4000 or more if possible. Very pricey RAM though, that is for sure.
I have looked at many ASUS Z390 OC guides. Though at the time, my focus was not on pushing RAM, rather CPU. I went back and had a look around from the RAM side of things and ran into a couple of guides that might be of use.
Questions:
If I use XMP to set up the DRAMs, it will over course set up all the voltages and what not. Now if I up the frequency, is XMP going to adjust the corresponding voltages as well for the DRAM kit and selected frequency?
Do you have any rules on how high the CPU VCCSA voltage can go without frying the CPU? The CPU is an Intel Core i9-9900K. I might be able to find this in a guide, but possibly you know?
In "lowering timings to optimize performance" - Are you talking about such things as CAS Latency and what not? I will likely need your assistance with this one... I will let you know.
Thanks for your help!
LB
Questions:
LB
