1.475v is that considered as a safe voltage?
  • 1.475v is that considered as a safe voltage?
    im running my G.Skill 3200 cl14 TridentZ rgb DDR4 at 3600, gear 1 and stock 14-14-14-34 timing at 1.475v. Is that a safe voltage for 24/7 use? Memtest86 passed.
    If so, is 1.5 safe or 1.6 maybe?
    Asus z590f and 11700k at 5.0/5.2ghz.
    Yes, that is a special kit so it does have those capabilities. 1.50V+ depends on if you can keep hardware cool during heavy duty tasks.
    With that combo you can take it upwards of DDR4-4000 as well
      Wow, nice. Very happy with it .)
        Is close to 60c ok? Bought another kit, so total 4x8 sticks running at 3600mhz cl14 at 1,475v and then temp got a bit higher becouse no space between them now.
          Maximum or average? If average, consider a memory fan to help disperse heat from memory slots area.
            Its Maximum when doing memory stress test, but also playing games like bf v make it go so high because the gpu is so close heating up the case. Have a fan was a good idea
