Just a heads up to anyone running this board, I tried to update my bios and failed half a dozen times using the auto utility on Asus's site to point me to the correct chipset/bios downloads... The issue is it was just pulling up info fo rthe P8Z77-V board, which is different from the LK model. You have to manually select this board to get correct bios/chipset stuff from Asus.
On the bright side once I did get the bios updated I managed to OC my ram to 1866 easily and been stable for a week.
I've sent Asus a ticket on that issue and maybe they can get it resolved, but I suspect this isn' the only board that works this way. So if you have an asus board just manually enter the model for correct drivers/bios download.
