Hi Everyone,
I am running into problems when trying to OC my PC and hope anyone may have a solution/suggestion.
When I use the TPU switch on the MOBO(designed to give me automatic OC to about 4.2 MHz), it has to reboot, but will get stuck in reboot cycles. Only option is to revert back to the Original bios state on the MOBO, which leaves me again with an un-OC'ed PC. Same thing happens when I use the ASUS software for OC'ing. I am totally unfamiliar with OC'ing, but built this rig to do so, with a few simple steps. OC'ing in the bios seems a bit too much for me. Also, I read that if you can use software/TPU switch, the CPU will not be stuck in the OC'ed state, which I prefer.
I have read about someone having installed the same memory, same MOBO and CPU, who had same problems as to mine. That thread ended with him/her stating he/she was now using a different brand of memory and everything was working fine now. I'm not keen on just buying new memory, becayse this is supposed to work.
Before I started the build, I did check compatibility with the MOBO, so I don't understand what the problem is.
Anyone here perhaps who has suggestions?
I have tried memtest, couple of cycles. No errors found.
Here are my (most relevant) specs:
- i5-3570K
- G.Skill 8GB (2x 4GB) Dual Channel Ares Series Memory Kit (DDR3 1866, 9-10-9-28, 1.5v, Intel XMP Extreme Memory Profile Ready)
- ASUS P8Z77-v Deluxe
- Asus matrix HD7970 Platinum
- Bequiet Dark Power Pro 850W
Any help would be greatly appreciated.
Dieek
- i5-3570K
Dieek
