Dear all
I need help and happy to get any feedback to get the problem solved.
Changed my rig from x299 Intel to X570 with ASUS ROG Formula VIII and Ryzen 9 x5950 in december. I kept my RAM (4x8GB) from the Intel platform (which was a quad channel platform). I do well understand, that the X570 is a dual channel platform.
My original RAM figures are: 3866 with CL18-19-19-39 1.35V
Started with setting my RAM to 3600 with CL16-16-16-36 1.345V and FCLK1800 on the Bios firmware from Nov/Dec...mostly it started, from time to time I had a 0D failure from my MOBO.
Now I upgraded the Bios to the latest version from Jan (V3022) - but the MOBO didn't start anymore - only in safemode. So I changed my settings to 3600 CL17-18-18-38 with 1.345V and it started stable...but also getting from time to time a 0D failure.
What do you recommend? I don't believe, that the timings are too agressive...and FCLK1800 should be possible I believe. Do I really need to looseing the timings to CL18-19-19-39? Or do I need to change RAM? Considered for example F4-3600C16Q-64GTZN or F4-3600C17Q-64GTZN...both are 4x16GB.
Any advice is much appreciated. Many gthx.
Best regards, JedimasterT
