F4-5066C20D-16GTZR Ram issue
  • F4-5066C20D-16GTZR Ram issue
    I bought this ram kit a few days ago but ı can not get them work 5000mhz. I reached to 4666mhz most.
    My system is:
    Asus x570-F motherboard
    ryzen 3800x cpu
    thermaltake taugh power 1200w psu
    And I increased soc voltage a little bit to 1.286 volt
    But ı need subtimings to reach 5000 mhz.
    Pls help me about it.
    Thank you by now...
    Is there anybody to answer this problem??
    especially authors plsss
      CPU is likely not capable. Also, if Infinity Fabric is not 1:1 then the overall system performance is likely not at it's best. For that CPU, ~DDR4-3733 is best
        Yes sir that is right I got a little perforfance increament.
        But I want to learn If İt can be solved next bioses??
        I mean , Do the engineers make it compatible to the next bioses?
          Yes, however it is not BIOS limitation, it is hardware limitation in this case. That is already well beyond any AMD Ryzen CPU and motherboard's optimal speed; hopefully in the next generation there will be significant improvement.
            Ok sir,
            Thank you very much for your response...
