New Build Questions/Concerns
  • New Build Questions/Concerns
    When I was putting together my build I didn't get any flags from PartPicker, until I was reading more about what I ordered.
    I have purchased the following:
    Asrock Taichi x570
    G.Skill F4-3600C18D-16GTZR
    AMD Ryzen 7 3700x
    When reading about the RAM and Mobo, there were questions about compatibility and I dug a bit deeper and found that this RAM was not on the QVL for the motherboard, but G.Skill has the MOBO on their QVL.
    Should I be concerned? I am still waiting for parts to arrive, so I can return the RAM if needed.
    Any feedback would be appreciated!
    No, G.Skill QVL is the most accurate list so you will be fine.
      That's what I was thinking, but wanted to make sure. Thank you!
