F3-2400C10Q-32GTX won't run at rated speed
  • F3-2400C10Q-32GTX won't run at rated speed
    Hi, just purchased Trident X F3-2400C10Q-32GTX but it won't run at rated speed for my Z77A-GD65-Gaming motherboard.
    If the memory is set to XMP profile 2400 10-12-12-31 I get some memtest errors.
    I can run at 2200 9-11-11-24 without issue. Not sure why it won't run at rated 2400 speeds.
    I have a 3770K OC to 4.7 Ghz CPU voltage at 1.29, all other voltages auto.
    Any ideas? Thanks
    Did you set the VCCSA Voltage?
    Post some pictures of BIOS and we can see if anything is incorrect.
      Hi, thanks for the reply. Attached are some images for my bios settings.
        To take screenshots from the BIOS use the predefined shortcut, usually the F12 key, to save them on an USB stick or any other FAT formatted medium (a cardreader with a memory card inserted works as well).
        VCCSA is System Agent Voltage in your UEFI.
          I set VCCSA to 1.25v and it did not help.
          What else can I try? Do I need to change any other settings?
            tRRD 8 and set the DRAM Voltage to 1.65V
            Do you have the latest BIOS?
              Hi, yes I have the latest bios. If use tRRD 8 the PC won't boot. I think I will stick at 2200 9-11-11-24.
              Thansk for your help.
                I put the same memory in my asus maximus v formula set it to XMP and its running great @ 2400 MHz . I'm also running the i7 3770k @ 4.7 ...
