Hi
I have the following RAM: RipjawsX Series 8GB PC3-12800 Dual Channel DDR3 Kit (2 x 4GB).
I got it last year when I built my AMD PC. Both RAM sticks were working fine until a few weeks ago when I noticed in the Task manager that one of the RAM sticks was showing as "Hardware reserved". I was only able to use 4GB RAM instead of 8GB like before (note I have Windows 8 Pro 64-bit, so it is not a problem of 32-bit Windows not able to address 8GB of RAM).
So I tried booting with 1 stick at a time to find out which stick of RAM was faulty. 1 of the sticks is perfectly fine. The computer boots up and I can see the full 4GB at 1600Mhz speed.
The second stick is faulty I believe. The computer does not boot up at all when I use just this stick. There is a solid red light on the motherboard. I have tried the following and it did not fix anything:
- MemOK button on the motherboard
- Different RAM slots
As I said the other stick works perfectly, just one of the sticks is experiencing the above problem. Can I RMA in this case?
