Is it doable to reach 4.2 ghz with this set-up by increasing the FSB from 200 to 240?
My limited knowledge tells me that this will make the RAM run @ 1600MHZ and would like to know what settings i need to do in BIOS and hopefully maintain a 7 latency speed, if this should work?
If the above is not possible, what separate OC settings do i need both on the CPU and RAM to achieve both goals (i.e. 4.2ghz on the CPU and 1600mhz on RAM).
I know that i should only ask RAM related questions in here but hey, i am so satisfied with the customer service here at gskill forums that i was hoping to get my answers here, so please bear with me...
Thanks in advance for your expert replies to a relatively noob OC'er.
Note: i have already installed aftermarket CM hyper 212+ in push/pull config and my temps now are 23 idle and never goes above 40 in prime 95 torture testing...
