I am having issues with my new ASUS P6P87 Deluxe and the 2 new kits of F3-12800CL6D-4GBXH (4x2GB) memory. When I have all four modules installed I can't enable the XMP profile or change any of the timings and have the machine POST. The only way to post is using the BIOS auto settings, which set the memory to the JEDEC #3 settings per CPUID (9,9,9,28@1.5V). I can enable XMP with each seperate pair of 4GB RAM installed, but once I install the second set of RAM the machine will not post. I have upgraded the BIOS to 1253 and I have run Memtest86+ for 8 hours with all 4 modules on Auto settings and had no errors. I have tried raising the DRAM voltage setting and the VCCIO setting, but could not find a stable setting. At DRAM 1.8v/VCCIO 1.25v, I was able to post, but Windows will not load and the machine locks up. I did not feel comfortable increasing those settings any further to see if I could get it stable. If you have anything else that you could think of for me to try that would be helpful. I just don't think that this is a case of bad ram, but I will let you be the judge. Thanks in advance.
Problem with (4x2GB) F3-12800CL6D-4GBXH with ASUS P8P67 Deluxe (BIOS v1253)
No, it appears to be a matter of two incompatible kits. If you need 8GB, you should purchase an 8GB kit.
Since you are beyond the return period, complete the RMA request form. When you email it to the RMA dept., let them know that you need a matched 8GB kit such as:
F3-12800CL7D-8GBXH
Then they can set you up with exchange details so you don't have to sell these kits to purchase another.
I bought the kit that has 4 sticks in it not 2 separate ones. I ordered the 8gb kit that has cas 6 latency and ddr31600. I expect that gskill will honor the warranty and replace for me the same kit and not a lesser speed one. Unless they want to give me one that is of equal or higher value.
All I did was set xmp and then tried auto and wont post. Is there any trick or anything that I could try to see if it will work or is it for certain an incompatible kit?
