Got a technical problem?
Thank you!
See more
See less
MX780 left mouse button click gets stuck or fails to click
  • MX780 left mouse button click gets stuck or fails to click
    I need to clean the area around my left button switch. It requires I press extra hard and longer before acknowledging or sometimes the opposite will happen it will become stuck down
    but intermittent and inadvertently click-drag such as on window scroll bars. Clicking on dialog boxes with text already present turned the text inverted as if I double-clicked.
    I lifted the plastic part up, blew into the switch area and the problem briefly fixed, but then returned. So I think I have debris under the button plastic which pushes onto the switch.
    I purchased the mouse from Newegg.com in December 2016.
    Any ideas on how to clean correctly will be appreciated.
    Money Talks!? All it ever says to me is "Goodbye!"
    It will be necessary to carefully and slowly remove the button, then clean the dust particles with an aerosol spray or of sort
    As long as the item is not damaged, you can also send it in for RMA exchange as you are within 2 year warranty.
    http://www.gskill.com/en/rma
