Got a technical problem?
Thank you!
See more
See less
Issue with MX780
  • Issue with MX780
    I'm having a few issues with my mx780 mouse. Whenever I apply lighting the mouse wheel light is out of sync and after a while, the mouse resets itself to a breathing effect even if I set it to cycle and the sync with system setting keeps turning itself off, I have tried reinstalling the driver and adding a different profile but it keeps on resetting. What can I do about this? I have emailed G.Skill twice and not heard anything back
    System info
    1. Software v1.01 firmware v21
    2. The issue started after using the mouse for a few days, it was updated on the first day of use
    3. MX 780 Gaming Mouse
    4. Windows 10 64-bit
    5. USB 3.0 back panel
    6 Gigabyte Aorus z370 Gaming 7
    7. Kaspersky Total Security
    8. KM780 Gaming Keyboard
