Got a technical problem?
Thank you!
See more
See less
Macro issues
  • Macro issues
    hello i have been using my mice for almost a year and lets just i haven slowing down in gaming but i started to play more and i noticed that the macros setting software isn't working anymore and i mean when i choose a characters for one of the button to be like the number 1 and then i click save to device memory and after that i try it it wouldn't do what it was supposed to do and stays to the default setting for either back or forward on the left side of the mouse . so if any can help explain what is going on it would help a lot because this getting irritating .
    If the buttons no longer work properly, reset the mouse to see if it works any better. If not, complete the RMA form online to attain a new mouse.
    http://www.gskill.com/en/rma
