Got a technical problem?
Thank you!
See more
See less
Led's reset to red after software restart...
  • Led's reset to red after software restart...
    Each time I open the software after waking from sleep all 7 zones reset to red. I change the colors back, re-save to device memory, and am all good til the next sleep. Any suggestions? I'm on W10 latest updates, FW21, SWV .78
    Please try the latest software version (1.00).
    Download page: http://gskill.com/en/download/view/r...r-gaming-mouse
    If you continue to experience the same issue, please let us know. Thank you.
      I've tested the new SWV and the problem appears to be fixed, thank you. MS OneDrive still starts up each time I save my settings for some reason, but I can live with that. If I discover any new issues with SWV 1.00 I will make a new post.
        Glad to hear. Thanks for letting us know! Although we're not sure why it would affect MS OneDrive on your system.
