Got a technical problem?
Thank you!
See more
See less
km780rgb win 10 sw 2.03 fw 76 - volume light display
  • km780rgb win 10 sw 2.03 fw 76 - volume light display
    hi
    every time I uncheck the 'disable volume display' once it restarts it is checked again.
    have created and save profile but makes no difference
    anyone else had this issue and any suggested solution?
    thanks
    stewart
