Got a technical problem?
Thank you!
See more
See less
KM780 RGB & MX Firmware Downgrade/Reset (Manual Firmware Update)
This is a sticky topic.
  • KM780 RGB & MX Firmware Downgrade/Reset (Manual Firmware Update)
    In some cases, firmware may be corrupt, causing usage issues on the KM780 MX/RGB keyboard. Please download and follow the instructions below to reset the firmware. The included firmware version is FW26 for KM780 MX and FW46 for KM780 RGB; please use the firmware update in the program files folder (folder name: FWUpdate) for later firmware versions. It's recommended to reinstall the software after resetting the firmware (similar to step 9c) to ensure matching firmware and software versions.
    -------- KM780 MX, FIX FOR WINDOWS 10 1809 ----------
    The update to Windows 10 version 1809 caused the KM780/KM780R MX software to be unable to detect the keyboard. The software is updated to version 2.00 (SW 2.00) and the firmware is updated to version 32 (FW 32) to resolve this issue. SW 2.00 and FW 32 must be used together. Using other software and firmware versions with SW 2.00 or FW 32 will not work.
    For the full guide, please visit: http://www.gskill.com/gskill-device/...-Fix-Guide.pdf
    Please make sure to uninstall previous versions of the software before continuing. You will also need to download the following ZIP files and then extract the contents to a known location.
    Firmware binary file:
    www.gskill.com/gskill-device/firmware/GSKILL_KM780_MX_FW_V0032.zip
    Software installer file:
    www.gskill.com/gskill-device/keyboard/G.SKILL_RIPJAWSKeyboard_KM780_MX_Setup_V2.00.zip
    Firmware Manual Update
    1. Unplug the keyboard from the PC.
    2. Locate the small hole under the leg standoff on the upper left corner (underside of the MR key).
    3. Use a paper clip, or something similar (at least 2cm long and less than 1mm in diameter), and insert into the small hole. You should feel a click or feel a switch/button pressed down.
    4. While it is being pressed, insert and connect both USB connectors. The keyboard will not function and the LED lights will not light at this time.
    5. Go to "“This PC"”, and there should be a drive with 64KB size (Drive Name: "CRP DISABLD" or "CRP1 ENABLD").
    6. Delete the drive contents (should be a single file named "firmware.bin"), and then copy the "GSKILL_KM780_MX_FW_V0032.bin" file into the drive.
    7. Remove the paper clip, and reconnect the USB connectors again.
    8. Once keyboard LED is lit up, confirm keyboard is functioning by pressing Windows key.
    Install Software (SW 2.00)
    9. Double click on the software installer file ("G.SKILL_RIPJAWSKeyboard_KM780_MX_Setup_V2.00. exe ") and follow the on-screen instructions to install the software.
    -------- KM780 MX INSTRUCTIONS ----------
    Download link for KM780 MX: http://www.gskill.com/gskill-device/...M780_MX_26.zip
    1. Locate the small hole under the leg standoff on the upper left corner (underside of the MR key).
    2. Unplug the keyboard.
    3. Use a paper clip, or something similar, and insert into hole. You should feel a click or something pressed down.
    4. While it is being pressed, insert and connect both USB connectors. Keyboard will not function and LED will not light at this time.
    5. Go to My Computer, there should be a drive with 64KB size (Drive Name: "CRP DISABLD" or "CRP1 ENABLD").
    6. Delete the drive contents (should be a single file named "firmware.bin"), then copy the GSKILL_KM780_MX_V0018.bin file into the drive.
    7. Remove the paper clip, and reconnect the USB again.
    9a. Execute and run FWUpdate.exe from the "FWUpdate_KM780_MX_26" folder, with Administrator rights (right click on FWUpdate.exe and click "Run as Administrator"). Wait until update is complete.
    9b. Alternatively, if the G.SKILL driver software is already installed, the paired firmware version can also be found at C:\Program Files (x86)\G.Skill\G.SKILL RIPJAWS KM780 MX\FWUpdate
    9c. If G.SKILL driver software is not installed, you may obtain the latest firmware version by downloading and installing the G.SKILL latest software driver from the G.SKILL website. (www.gskill.com/en/download)
    -------- KM780 RGB INSTRUCTIONS ----------
    Download link for KM780 RGB: http://www.gskill.com/gskill-device/...780_RGB_46.zip
    6. Delete the drive contents (should be a single file named "firmware.bin"), then copy the GSKILL_KM780_RGB_V0037.bin file into the drive.
    9a. Execute and run FWUpdate.exe from the "FWUpdate_KM780_RGB_46" folder, with Administrator rights (right click on FWUpdate.exe and click "Run as Administrator"). Wait until update is complete.
    9b. Alternatively, if the G.SKILL driver software is already installed, the paired firmware version can also be found at C:\Program Files (x86)\G.Skill\G.SKILL RIPJAWS KM780 RGB\FWUpdate
    Last edited by G.SKILL; 12-25-2018, 12:40 AM. Reason: Updated with KM780/KM780R MX keyboard detection issue fix on Windows 10 version 1809
    you're kidding cannot access this via programming
    a paperclip
    This firmware is Keylogging us I was on up to date drivers now I'm on MS drivers no gskill stuff and months later it just reoccurs?
    MY RIG:
    "THOR's Hammer"
    http://www.modsrigs.com/detail.aspx?BuildID=35441
      So I was getting the error that this guy was getting, https://www.gskill.us/forum/showthread.php?t=13985 , so I clicked on the link he was told to fix his issue, and I followed the steps here. I managed to get the keyboard to let me access the 64kb drive, but no matter how many times I unplug it and plug it back in it will not light back up, and keeps letting me access the 64kb drive even when I dont have anything in the hole to depress whatever switch is in there.
      How do I fix this? I had to get my old membrane keyboard out just to type this up.
        I have the km780MX and everytime I plug the keyboard in it just pulls up the CRP1 ENABLD drive
          Snebbik,
          If you aren't pressing down on the pinhole switch when plugging it in (and you've already copied in the correct firmware BIN file), and it's still giving you the CRP1 ENABLD drive, then the switch is probably stuck. Try inserting a paper clip in the pinhole and click a few times to see if you can get the switch to un-stick.
          If that doesn't work, then you'll probably have to RMA the keyboard.
            Okay, so my many issues I've been having with this keyboard, all which started about five months ago, is the sole reason I joined this forum. I immediately noticed this post and went through the procedure. I wasn't aware of the reset hole below and how it could be used to access the onboard memory. This actually gave me some hope.
            I inserted the paperclip and was able to delete the .bin image file from the drive, then copied over GSKILL_KM780_MX_V0018.bin and proceeded from there. I tried to re-flash the newest FW, which is stored in the "C:\Program Files (x86)\G.SKILL\G.SKILL RIPJAWS KM780 RGB\FWUpdate" directory, but it would fail and tell me to unplug the device and try again. So I then flashed the older FW provided in the file download above, which actually worked. From there I was then able to flash the latest FW, again from the "C:\Program Files (x86)\G.SKILL\G.SKILL RIPJAWS KM780 RGB\FWUpdate" directory.
            From here, I just set everything back up like I had it from scratch. I use four of the Macro keys and set them up, as well as the default three hardware profiles I use (lighting settings and all). After this, I exported each profile just to have them in case I needed them, because for months now I've had to use them whenever the keyboard simply faults out in numerous, very strange ways. I've had it COMPLETELY DISABLE all the keys upon a cold boot, which is the craziest thing. This forced me to temporarily connect another keyboard just so I could log-in and use the "KB_HW_Reset.exe" utility that's in the program directory. I've come to know this utility very well, as I have to use it at least twice a week when something goes wrong.
            In addition to the issue with all the keys simply disabling themselves, I also have had my Macros simply delete themselves, or change to different keys without explanation. NOTHING about what happens makes any sort of sense. There is no pattern to it. About the only fault I can continually reproduce is whenever I have the main software window for the keyboard open, switching to the M3 profile causes it to crash about 70% of the time. After crashing, it will usually screw up my profiles completely and simply importing them back in doesn't work without a complete reset first.
            I was about to give up completely, until I decided to come here to see if I could learn anything I haven't tried. This was something I didn't try. Sadly, even though I was able to reset the FW as shown here, then reinstall the software, I'm still having issues. I've already had the dreaded M3 crash so I'm assuming nothing has changed and when I reboot I'm going to have the same exact issues.
            I was sent this keyboard as a review sample from Newegg as I am an eggXpert reviewer for them. I liked it so much at first that I bought the MX780 mouse to go with it. But now it's been just two years and these game-breaking issues that started five months ago have completely changed my opinion about this keyboard. The hardware seems fine, but the FW and software are flawed beyond repair, at least in my revision.
            I'm running the Cherry MX Brown switches on a Gigabyte Z97X-UD5H MOBO, i7 4790K CPU with 16GB of DDR3, and a 1080Ti GPU. My OS is Windows 10 Pro x64, version 1803 (these issues occurred in 1709 as well).
            I don't think I can even RMA this unit as it's just slightly past the two year mark. But I'm going to update my EggXpert review on Newegg to let everyone know that there is something seriously wrong with these keyboards. It could just be an isolated case, but I've seen way too many people with the same exact issues as mine. I'm starting to think that the driver software is corrupting the FW when running on later versions of Windows 10. It's really sad because this is such a great keyboard when it works.
