Got a technical problem?
Thank you!
See more
See less
volume control don't work for some channels
  • volume control don't work for some channels
    I have the SR910 Real 7.1 headset, and when i'm using the remote to control the volume of some channels (rear, ctr and side) I hear nothing different. It's working with main, front, and sub channels but not with the others.
    Is that normal ?
    Thanks for your answer.
