G.Skill F4-3200C16D-32GTZN Trident Z Neo RGB 32GB 3200MHz DDR4
  • G.Skill F4-3200C16D-32GTZN Trident Z Neo RGB 32GB 3200MHz DDR4
    Hello
    I bought "G.Skill F4-3200C16D-32GTZN Trident Z Neo RGB 32GB 3200MHz DDR4" memory to put in my "ASUS TUF Gaming X570-Plus (Wi-Fi) Motherboard" (latets bios 1005 with a Corsair HX1200i 1200W Power Supply but the memory is running at 2133Mhz. CPU 3700X (Stock Clocks)
    I have Enabled D.O.C.P then DDR4 3200Mhz (1.35v, 16,18,18,38) but the memory wont post and I have to drop back to 2133Mhz
    How can I get this memory running at 3200Mhz
    Are modules installed in second and fourth slots away from CPU? Test each individually to see if each can boot and run at the rated specs.
      They are in the 1st and third slot.
        Memory is in A1 and B1 (not A2 and B2)
          de_overfiend on OCAU forums said to try A1, B1 memory slots not (A0 B0) this worked. 3200Mhz now.
