Got problems with my G.Skill Trident Z RGB DDR4 3000MHZ 16GB
I installed the latest software from Gskill and followed all the steps that where mentioned.
But one rgb now only flashing in red. While before everything worked perfectly fine.
also one of the two is showing in bios with no manufacture of gskill.
So took the following actions to try solve it:
Bios update
Switched them from places since i got only 2 slots for ram
Reinstall the program with all the steps you guys state on site in red -> no luck
Even did clean install of windows and still the same.
Bios update
