Would this build cause any trouble with tridentz RGB?
  • Would this build cause any trouble with tridentz RGB?
    Hello guys,
    Im almost finished building a new RGB system, only ram left to buy and thinking about getting the TridentZ RGB 16GB (2x8GB) 2400mhz F4-2400C15D-16GTZR, would it cause any trouble with this following hardware parts? i've heard this ram go dead
    MOBO: Gigabyte GA-Z270X-Gaming K7
    GPU: GALAX GeForce® GTX 1070 EXOC-SNPR WHITE 8GB
    AiO Cooler: NZXT Kraken x52 & NZXT HUE+ lightning and fans.
    Thanks in advance.
    Originally posted by Antartiida View Post
    Hello guys,
    Thanks in advance.
    I don't think there is any widespread issue with the RAM not working as RAM, but the RGB LEDs are still a work in progress.
    Keep in mind, when someone has dark LEDs on their sticks it is not physically broken, it is a software problem and it is fixable.
    Gigabyte Z270 Gaiming 7 (GA-Z270X Gaiming 7) BIOS F4
    Intel i5 7600k
    Gigabyte GeForce GTX 1070 G1 (GV-N1070G1 GAIMING-8GD)
    4x G.Skill Trident Z RGB (DDR4 2400 - PC4 19200)
    1TB Samsung 960 EVO
    Win10 Home 64bit
      But is it fixable without sending them back? as im not in USA, so it would be a lot of work for me to send it back over.
        Yes, in most cases it is a software issue or compatibility issue with the motherboard / hardware
        The RAM is good for that motherboard
          Thanks G.Skill for answering and confirming this
