Hy, as you can see one of my rgb module is dead only the lowest part of module is lighted up and its stays that way no control whatsoever and also makes a noise coil noise not loud with side panel on the case but when i take off you can hear it. The MB is gigabyte AX370-Gaming K7.
One of my modules Rgb is dead
1. Yes F3
2. The recomended way slot 2&1 (the busted one is in slot 2)
3. Yes tried default unistall, install again the one that is good is working nice no problems but the busted one i think the rgb controller is gone cuz its make coil noise.
The 1st ones are 3000mhz and tomorow i sent them back, I ordered 3200mhz still tridentz rgb cuz they are the most kickass looking ram(my personal opinion) kudos for that G.Skill but i don't install the software until its safe or official. So good luck with resolving bugs.
